L&J is OK!
Yeah ...what Joe and Hornet (Rick) said...
I'll add...that you need to check the track for flat before you waste ANY time on it. Aurora only made two pieces of warped track the "bump and the "bridge". All others need not apply. So after you've checked them for flat, then check that all the rail spring tabs are present and adjust any that are mashed down. I also like have a look across the track from the sides and make sure the rails arent noodled around high and low. The rail should protrude uniformly from the track surface along the entire section. Then inspect the lock, joiner, and screw holes for damage. If thats all skookum, THEN start the cleaning process. :thumbsup:
Again like Joe sez, stackem' up and have at it with the zippy brush. Be sure to wear those grippy canvas backed rubber dipped gloves. Helps ya hold the stack of track firmly and protects your lil finners when you go off course.
Although it's been a while, I used 600 wet and dry paper on the rails during the wash and scrub portion of the restoration process. Just wrap it around a chunk of hardwood or block. Ya gotta be careful here. If you dont pay attention and stay on line, you can scuff or scratch your white centerline. I scrubbed mine up with a brush in a big old bucket of **** and span and warm water. Once I got them all washed up nice and clean. I wet sanded the rails right in the same bucket. If ya stand each piece up on end on an old towel as you go along they'll gravity drip out nicely and almost be dry because you used warm water. At that point I blew each piece thoroughly dry and hosed them down with WD-40. Finally, I just buffed off the excess WD. For periodic maintenence, I wipe the track down with an automotive bumper black and buff it off. For spot cleaning the rails, I use the old school Atlas train rail eraser block, but any ole fine grit firm bodied pen eraser works great.
You should also be prepared for snags at the rail joints after you begin assembling the sections. It's not uncommon to have to dress them. I use a good sharp flat file. Then dress again with a fine hone/stone, and finally spot sand the area with 600-1200 wet and dry paper. Your pick up shoes will thank you. Remember to vacuum up all the crumbs or they'll be stuck to your chassis/magnets in a nano-second.
If you get organized beforehand, you can make short work of it. If ya dont have them get some extra locks. Like all plastic, the age too. It's not uncommon to have a coupla blow up on ya, after you bring them out of retirement. :freak:
It's always a good idea to check the terminal track and controllers before hand too. Hookem' up first and see what ya got going.
Good luck!
