SPEED secrets???? shhhhhh
2896 Views 30 Replies 11 Participants Last post by  sg1
OK Andy, Micro, etc...
several claimed they would share their speed hints/tips after the season was over...
Time to fess up or spill the beans...quietly of course.
RAFster
1 - 20 of 31 Posts
They key to going fast is not to get into wrecks!!!!!!!!
Key to going fast is getting the track early enough to set up and practice. Practice Practice, Practice, Practice. When you finish that practice again!!!!!
What do you mean by getting to the track early enough to practice??? I think you may be directing this toward someone in particular!!!
Doesn't hurt to have a good handling body on the car hahahaha.
Yes like that yellow one!!!!!!!!!!!!!!!!!
I am working on my web site....it will have all the speed secrets..... But Tang is right, if you can't stay off the walls, they won't help --- SLOW IS FAST!
Now who said slow is fast ??????
But, one must not forget, 2slow00 has proven he is not too slow.
Trophies don't lie do they?
RAFster
Micro, when I get back from Wisconsin I will send you a copy of my file to add to your website.
Boy, I'll be looking for that!
I picked up several go fast tips at the last race at BRP World Headquarters. Bud always manages to have some new goodies as well. Haven't taken time to build the v2 yet, hope to soon.
Warbird: I've been working on that project we talked about...if you get a chance, could you email me the link? Thanks
From Micro_Racer in another thread...
Many SC-18 racers have had the same problem with the rear screws loosening -- a few tricks are:
1. Put a dab of Lock-Tite on the screw - that will prevent them from backing out
2. Super glue the pod plates to the T-Plate top and bottom - if a screw backs out it should hold for the race.
3. This is what I did - buy a 4-40 tap it will come with the drill bit, tap the pod plates and top, bottom T-Plate and use the Associated Button Head Socket Screw 4-40x3/16" part number 6920...I have never had that problem again!
Two things that will help:
1 -Polish the kingpins, front axles and pivot ball ( on the v2 chassis ) with a quality metal polish like Semichrome, Flitz, etc. Use a Dremel tool or drill motor to hold the piece and a piece of cloth with a dab of polish.
2 - Preperation. Get the car ready before you get to the track!!!!!!!!!
Speed Secrets
A few speed secrets that will really help!
  • For the past year I have kept a log of every race. In my notes I have car set-ups - -- tires, tire compound, pinion/spur gear, springs, and any other use full info. This brings me to secret number 2.
  • Have you car ready BEFORE the race. Looking at past races I get a good idea of what worked and what did not. My goal is to have a fast 1st heat.
  • Clean and oil your car after every run. So many people just charge the batteries and that’s it! Clean the dirt and fuzzy’s out of the motor and everywhere else!
just a few simple tips....:) :)
run 8 cell / s300 6.0 v + attach "D" rocket motor
Better tape a rock on the roof and paint it florescent red so you can find it again!
Here is a good one I got from SG1 large associated damper disks with O ring instead of the stock ones use 100 weight Losi shock oil fill the area around damper post then put the top disk on.
The SC18 V2 kits will come with the larger disks also the conversion kits have them. :thumbsup:
1 - 20 of 31 Posts
