I found that the fuse (30 ampere?) was internally blown. What is the proper ampere? I put a 15 ampere fuse in the holder & turned switch to start. The engine turned over but did not start before blowing the fuse. What would cause this to blow? Are key switches grounded thru nut holding it to frame?
THANKS,willie
I'm having trouble finding an electrical schematic for that machine, so I'm not sure how many amps the fuse should be. I found some parts diagrams, but they do not mention fuses:
http://www.partstree.com/parts/?lc=snapper&mn=28085+28%22+8+HP+Rear+Engine+Rider+Series+5
Machines I have repaired in the past took 20 A fuses. Keep in mind they are propane burnishers and not lawn mowers, but it's still a 12 V starter cranking a 17 HP engine so I would imagine the amp draw is similar.
As far as I am aware, key switches are grounded to the frame through their chassis and nut.
Before you install any more fuses, you will want to make sure the wire running from the S terminal on the key switch to the starter solenoid is not shorting against the frame. Visually inspect it.
With the key switch in the off position, set your multimeter to continuity. Connect one end to the wire leading from the key switch to the starter solenoid, and touch the other end to ground. You should have no continuity. If you do, the wire is shorting out.
If not, try a 20 A fuse. If that's not enough - and since it had a 30 A fuse when it was brought in to you - you might want to try a 30 A fuse.
I had a similar problem that was driving me crazy with an Onan Performer popping fuses. The starter would crank in the start position and continue cranking in the run position until the fuse burned out.
Because of the way the engine is wired, it requires a diode to be placed in the start circuit to prevent voltage leaking back from the run circuit. The diode was bad and allowed voltage to flow backward. Kind of unusual, but in the end it turned out to be a simple repair.
If there is in fact a diode on your machine, and if it is bad, you can usually find them hiding within the plastic tubing surrounding the wire harnesses. It's likely on the main bundle that leads up to the starter switch. They're wired inline, either soldered or plugged in.
If you have a diode and you'd like to test it, you first have to isolate it. Disconnect it from both wires. With your multimeter set to resistance, place one lead on each end of the diode. Now reverse the leads and repeat. You should have infinite resistance in one direction and very little or none in the other direction. If voltage flows both ways, or doesn't flow either way, the diode is bad.
I hope that helps you out some.
