1 - 20 of 52 Posts
Discussion Starter · #6 ·
well i had to much oil in before i changed it, so all i did was change the oil and its the proper amount, but the needle in the bowl (adjustment)had a grove from the tip upwards to the thread part , and so does where it seats, could this be the problem
thanks
Discussion Starter · #10 · (Edited)
i do believe that the needle and seat kit comes with the carb kit so i will be puttin a new one in or if it dosen't i will be puttin one in, could the needle and seat be the blue smoke problem, because its not goin down on oil,, thanks
well good luck =-) and forgot to add in my b4 post, check the head gasket, if its not torn up or melted to the head/cylinder its usuably, wipe off ALL dirt and grime, if its on top / bottom of gaskets it could cause uneven head top when screwing on, resulting in losing compression
Discussion Starter · #17 ·
i guess i'll put a head gasket on it because when i removed the head a week or so ago (that was when i broke the head bolt off), so im just gonna buy a head gasket and a helicoil insert so its alback together properly and finish rebuilding my 12hp i/c :thumbsup: ,, thanks
1 - 20 of 52 Posts
