Better, with a metal gear...and 1/3 $Please do the specs on that servo seem close to the futaba
Many Chinese companies are blatant, shameless copycats. Their government turns a blind eye.http://www.hobbyking.com/hobbyking/...Gear_High_Torque_Servo_5_7kg_11sec_29_5g.html
I've got a couple of these coming...will let you guys know what I think. Interesting part number, huh?![]()
Dave, please explain this part - do you just use a horn? thx....without a servo saver and still work great.
I would guess to keep it as tight as posible. I think he also puts rubberbands on the links to keep the ballcups tighter as well.Dave, please explain this part - do you just use a horn? thx.
I use the standard black servo saver but take the spring out of it and bolt it together so that it makes it solid. No give at all and the Savox servo has held up perfectly to it.Dave, please explain this part - do you just use a horn? thx.
When you use rod ends. Do you use a differant steering turnbukle?I use the standard black servo saver but take the spring out of it and bolt it together so that it makes it solid. No give at all and the Savox servo has held up perfectly to it.
I don't run rubber bands, I use rod ends from servo city and not the ball cups.
Yes, I use shorter Tie rods. I can't remember the sizes off hand though, sorry. Something an 1/8" or so would be fine I would guess.When you use rod ends. Do you use a differant steering turnbukle?
I got some dubro rod ends (w/440 holes) the assembly was too long. I was thinking 12th scale steering ty rods...but I thought I would ask first. (This time)
I have been running the Solar 658. It is about $13 from Hobbypartz, it is fast, digital, coreless, metal gear, ball bearing and more than enough torque for a pan car.im new and want advise on a servo for a Rc10r5o..
I would like to buy one from hobbypartz.
