In HO Scale!
Looks like a go kart frame. Well done!In HO Scale!
I assume the rear cross member is temporary because I don't see how you would get a crown gear in there. Maybe it's the camera angle.
Good point, which is why I was curious about the base design. Upon closer inspection of the pics I do see that the rear members are asymmetrical. Anglewinder probability is high. I am curious about how the motor will be mounted and how those front facing rings are going to be incorporated into the design. Part of the pickup system??? Some sort of drop arm or pan???I think this is an anglewinder chassis
Torsion bar mounts! :thumbsup:..... I am curious about how the motor will be mounted and how those front facing rings are going to be incorporated into the design. Part of the pickup system??? Some sort of drop arm or pan???
