Thanks, they were easier than I thought that they would be, drilled out the holes with a 3/32nd bit at the proper angles and glued short sections of 3/32nd evergreen tubing into the holes. After they dried I carefully trimmed them down almost flush and sanded them to blend it into the hull. I used a #11 blade to wallow out the ends of the tubes to give them a slightly conical shape inside.Can't get over how good the rocket nozzles look. đź‘Ť
This has a vague resemblance to the Spindrift from Land Of the Giants. It has the forward crew compartment, three people instead of two people as in LOTG, an airlock area between the crew and passenger compartments and an aft engine section. Of course the same correlations could probably be made to many sci-fi spacecraft.Reminds me of some Hanna-Barbera cartoon spacecraft--kind of like something you might see in the 1980s update of Space Ghost. đź‘Ť
