1 - 13 of 13 Posts
A few weeks ago I bought my first LIpo Orion 2400 and had a guy at the track set up my ICE to charge it. While charging the pack puffed up and was unusable. The shop I bought it off of refunded my money no problem and I haveb ought another one. Now I am worried about charging it because the same thing might happen. Here are the settings I have now on my ICE.
Lipo 7.4V 2400 MAH
Chg Current 2.4A
Dchg Current 2.0A
Dchg Volt 2.8 V/C
Cut off Temp 90
Max Charge Capacity 90%
Now when I charged the other one the LIpo was set at 5000 MAH and the Chg current was set at 5.0. The Max charge Capacity was set at 110%. I looked at the guys chrger who set it and that was the same he was charging his at on his ICE. We all agreed the battery was the problem but I am worried about lighting this one up in my shop. I have a race with it on Sunday so I have to do something. Please tell me if these settings are ok or if I need to change them
Thanks alot.
Bob
When you press the button to start the charge, make certain you don't change to a different batt profile. I saw I guy set his Ice for a 3200 lipo and press the button but he must have pressed it crooked as it switched to NIMH and puffed the lipo. Just a thought.
Used to be racer......
That's because you have one of those single cell equalizers from MaxxGullo Motorsports. ;) :lol:
Sometimes When you press the button to select charge or discharge with the ice the dial can turn & give you dischsrge & change to the next battery select. This has happened to me several times. Now I always read the screen after starting it. Other than that no problems.
pancar schizophrenic
yes that is true i forget about that, i built one into my GFX so i dont have to worry bout it anymore!!!
1 - 13 of 13 Posts
