1 - 3 of 3 Posts
I am just seeing if anyone has had the same problem or give me something to look at. The last 2 races my motor which came with the truck the 3300 because i bought the brushless version, has been running 180-190 not matter what gearing i put in it. I feel this is to hot anyone have any thoughts?
I started out with the stock gears 87 spur 18 pinion and was down to a 15 and the motor still comes off at the same temp. the track isnt huge that we are running.
CHECK THE TRANSMISSION, the 3 long screws going through the case halves and into the motor plate, they are probably to tight, remove them apply small amount of thread lock blue or green, then install back into trans. lightly tight them, then back off a half turn.
1 - 3 of 3 Posts
