Hey, gang!
Well, things have finally settled down enough that I've had time to chop up my pics in Photoshop & get them posted. Here's a present that I built for my Dad for Christmas, the pickup truck from Sanford & Son, one of his favorite shows.
I used the opening from the show for most of my references as it showed both sides of the truck, as well as some pics I found around the net. The most significant thing I had to do was modify the grill from the kit's '50 to a '51, cutting it taller & wider, also using a GK part from Kitchen Table Productions. The bed of the truck had molded wood, so I covered that with stained coffee stir sticks & used pastel chalks to dirty it up a bit. All of the grime is from chalks & the rust is a two-part process I found at Michael's that uses paint with iron filings in it, so it's real rust!
I covered the seat with foil to give it a more natural look, & then taking inspiration from a truck at work, I made a rip in the seat, painting the "inside' yellow to look like foam. The seatbelts are scratched with plastic & gaff tape, which is kinda like duct tape.
The driver's window was cut so I could shove it in the door to look "rolled down". The spare tire post beside the passenger door is scratched to match the show truck. The lettering on the door is hand painted.
Enjoy!
From the opening theme:
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/truck1.jpg
The build:
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_2004.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_1991.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_1985.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_1997.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_1990.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_2000.jpg
http://i239.photobucket.com/albums/ff5/Prince_of_Styrene_II/Sanford truck/IMG_1998.jpg
Enjoy!
The build:
