I have a Ryobi weed eater model RY30020B, it starts fine and idles fine but when the I increase the throttle it boggs down. I pulled the carb off it is soaking in carb cleaner right now and has been since last night also took the bottom of the carb off and seen the diaphram looked wore, could that be my issue if so does anyone know the part number. Your help be appriciated and Thank you in advance.:)
Thanks for your help geogrubb it is a walbro carb I went to the local small engine shop purchased a G/D kit, found a breakdown of the carb and it took right off and ran like a champ. So thanks for your help and quick response you keep me from spending more $ then I had to.
