Hi guys, I just joined the group hoping someone might point me in the right direction with my problem.
I have a Ryobi blower/vac with the 25.4cc "full crank" engine which up until yesterday, has always started easily and run fine. My wife first told me that she couldn't get it it to start and that she thought the pull start was slipping as there was little resistance when she pulled the cord. It felt to me like there was normal compression if I pulled the cord slowly but if I yanked it, it seemed to almost freewheel. I pulled it apart and the start system looks fine. I pulled the plug and it was wet with fuel. I grounded the plug and pulled the engine over and there is spark. I removed the carb and exhaust to look at the piston and the rings are there and literally nothing on the piston, no scores or scratches and it moves up and down. I put it all back together and same result although now the compression seems to be normal when pulling the engine over. My imagination? Possibly... It will not even fire with a gut full of Aerostart.
Is there a keyway that the flywheel locates on that might be sheared? Is it possible the shaft can half slip half grab with a sheared key?
Any help will be greatly appreciated. Thanks
