In the process of building my Factory T4, I have considered going with the RPM cups based on what I've read about them being better. Is this just hype or are they that much better?
I don't know about being better, I prefer the RPM cups due to being stronger. I have never broken a ball cup but since the switch to all RPM cups, I have not had one pop off during a race.
RPM's are most definitely better as they "snap" on tighter and are more resistant to popping off or distorting in the advent of a crash. My personal experience is that the Black RPM's have always worked great while the blue or neon yellow ones have been hit or miss over the years to where I only run black RPM's.
I put AE cups on my pan car and I find they pop off really easily. I was shocked that even with new pivot balls there was still slop in the steering. Ended up having to put o-rings under the ball-cups.
I'd say go RPM. Better but more expensive - worth it.
if you are talking about comparing the RPM's with the old Small WHITE AE's...
Yeah, you'll be HAPPY as HECK w/ the RPM's. I use the LOSI ones too and like them.
I HAVE had some of the RPMs almost fit the ball TOO TIGHT though, and cause some drag on a servo. (Make sure the don't bind you up)
Yeah, RPM cups are good, but there's nothing wrong with the Associated ones, either. Never had an issue with the ones I use on my TC4.
