Robitronic have introduced these two new receiver packs featuring a hard case. Often the 7.4 volts that come from a LiPo pack is too much for receivers or servos, so if you don’t want to use a regulator you can use Robitronic’s LiFe Packs which output 6.6 volts directly. The hump pack weighs 95 grams and has a capacity of 2000mAh while the stick pack is 1600mAh and weighs 80 grams.
Source: Robitronic [robitronic.com]
More...
