i run mine 4.5 l/f - 5.0 r/f - 5.5 l/r and the r/r is what it is. if you get the other three right the r/r will be close
do yoiu set your ride hieghts with the tires at the smallest that will be ran and leave it? Or do you change ride hieghts as tires wear?
i change it as i go if i need to.. but usually you have more than one set of tires that are all cut to the same size, so as you change up tires your ride hieght will remain the same...
