Its been a while since I was here last.
Anyway. I have an old lawn chief tractor that had a 12 hp engine with a single wire with a red cap around the connector. I replaced that engine with an older (early-mid 90's) opposed twin 18 hp engine. The problem is that the wiring is different.
On the old tractor, there were a total of 3 wires on the engine. The main hot lead going to the starter (same on the new engine), a black wire that I think is just a ground (goes to the throttle linkage on the old engine), and the wire I mentioned above.
The new engine on the other hand has 3 wires compared to the 1 charging wire of the old engine.
The new engine has a single wire with a round plug with black covering and 2 more wires going to a double plug. What is the best way of wiring this all together so that it works properly?
Thanks...
i think theres a block that B&S sells that you plug in the 3 wire and it breaks it down to the single wire, its alittle block. Im almost positive I seen on of these before, can you tell us eninge numbers (model, type, code)
Discussion Starter · #8 ·
BTW I mean to clarify my first post. The lawn cheif tractor is from around 1987, the new engine is from the mid 90's or so.
I re-read my first post and realized that I made it sound like that the replacement engine is older than the orignal.
