I have a 2017 Toro Personal Pace mower with the above engine. Someone had tossed this mower since it needed a new carb. I brought it back to life but on my initial checks it barely had any oil. It worked for a while but now has almost no compression.
I'm trying to find a replacement engine for it since its a good mower if they can be had for a good price. What I found so far is that I can replace it with a 104M02-0180-F1 but can't find any specs as far as shaft size etc for these.
Anyone here happen toi have access to spec sheets for either one of these two engines?
Discussion Starter #2
So far I took measurements of my engine.
25mm
3 5/32 length shaft
3/16 keyway
Tapped 7/16 20
