1 - 3 of 3 Posts
I'm fairly mechanically inclined and I have already fixed the problem on the engine. Never have done small engine repair so just wanted some guidance.
I'm putting the engine back together and now starting to worry about the timing on the engine. I forgot to mark the gears to know where exactly to put them back. I know it does have the key timing gear which connects to the camshaft.
Anyone have any advice on how I need to position those gears correctly so I have the right timing?
BRIGGS AND STRATTON
14.5 hp I/C
Model 287707
Type 0220-01
Thank you!
The gears are already marked at the factory. There will be 2 marks to line up, 1 on crankshaft gear, and 1 on the cam shaft gear. Align timing marks on cam and crankshaft gears so they are together.
1 - 3 of 3 Posts
