LED Burner Outer
I had about the same results with paint thinner and a small square of paper towel. The ridges and high spots tend to burn through the unwanted tampo and the underlying paint too easily, while the flat panels need a scrubbing.
This worked for me...
Disclaimer - old data.
I have used denatured alcohol and a cotton swab to remove the graphics from an AW Firebird. Just dip the swab into the alcohol and carefully rub on the graphic only. Take your time. The results were great. I have not tried to remove the graphics from the Bowtie series.
I tried the alcohol trick on a AW firebird and burned through the paint, also tried pinsol and a grafiti car and no real luck it is still soaking for a month now
LED Burner Outer
Ain't it funny when you try to strip all the paint off you can't, but try to remove a design off the body and the paint comes off easily!! :tongue:
