... DETAILS close-up ...
Thank you 'Stang' ... your praise feel great !!
Here are some CLOSE-UP IMAGES of those details.
... images previously seen ...
Thank you again.
Primo! From the lines on the cab down to the wheels for the second trailer (is that little set called a pig?) it's top notch all the way.
Discussion Starter #8
... thank you ...
Thank you ... ALL of you, for your kind words of praise.
'jitte', you asked if "...that little set called a pig?".
If you mean this particular section of the combo :
in the trucking industry, it is known as a 'con-gear' (connector-gear).
For this project (to tie its name in with the names of the other sections)
I'm calling it TRANZ-LINK ... tandem-link for the trailers.
Its wheel-set would be identical to all those used throughout the truck.
All would be 'super-singles' wide-body low-profile Kevlar-sleeved rollers.
