Does anyone know of a refit plan that shows an accurate cross section through the saucer?
Mr. Scott's Guide to the Enterprise has a section but it makes the lower, outer ring (the flat area) *MUCH* too wide. All the other cross sections I have found have the same flaw -- presumably a having a synoptic ancestory.
For example, compare the thickness of the flat area on your refit kit or the the motion picture to
http://www.cygnus-x1.net/links/lcars/blueprints/enterprise-deck-plans-sheet-4.jpg
If you have those pictures from the auction, compare eaDSC07575.JPG to the above.
