Thanks to advancements in battery technology, 1:8 electric buggies and truggies are destined to be the next big racing class. Reedy have released the powerful and reliable Sonic 1512 competition brushless motor which has been designed specifically for the 1:8 electric buggy and truggy classes. A precision-machined case features an integrated heat sink to lower operating temperatures, which results in less fade over the course of a race, longer run times, and increased motor life. Sensored operation results in a smooth and controllable power band, while a high-torque 4-pole rotor featuring neodymium sintered magnets is supported by precision ball bearings for maximum power output and reliability. A choice of three versions means that there is a Sonic 1512 competition brushless motor to suit most tracks and conditions.
Features
- Dual precision ball bearings
- High-torque 4-pole rotor
- Neodymium sintered magnets
- Integrated heat sink
- Heavy-duty solder tabs
- 5mm shaft
- Sensored or sensorless operation
- Competition proven
- 200mm sensor wire
- Built to ROAR specs
- 5mm shaft
- 200mm sensor wire
Specifications
- Cells: 2S-4S LiPo
- Diameter: 38.9mm/41.5mm (w/fins)
- Length: 65.0mm
- Shaft Diameter: 5.0 mm
- Weight: 310-320g
Source: Reedy [teamassociated.com]- Cells: 2S-4S LiPo
- Length: 65.0mm
- Weight: 310-320g
More...
