1 - 1 of 1 Posts
Reedy introduce the 250mAh 6.6V LiFe RX battery that is perfect for use in 1S powered 1/12th and 1/10th pan cars that require a receiver battery. The battery sports dimensions of 34.5x21x11.5mm and its LiFe chemistry provides voltage similar to the ESC’s BEC voltage output, resulting in servos that run as intended in terms of speed, torque, and reliability. The battery features an integrated switch so that the car can be powered on and off conveniently. A separate non-switched charging jack means that the battery can remain plugged into the receiver during the charging process. The 250mAh capacity is good for a typical day’s worth of pan car racing.
Source: Associated [teamassociated.com]
More...
1 - 1 of 1 Posts
