I have a Red Max GZ25N. Cleaned carb. Checked Vacuum and Pressure; found cylinder gasket pinched. I replaced it. Holds vacuum and pressure as long as i block the ports for the reed valves.
This trimmer will sometimes run on first pull and run ell. shut it down and it won' always start. cold or hot you cannot start it to save you r life.
I tried different spark plug, coil. same problem. What an I missing?
Thanks for any and all suggestions.
BOB
BOB
