Things to check for:
1. See if the Cluster Gear(the one at the back of the gear plate) is sitting at an angle(cocked to one side or the other). JW's sells steel screws to replace the rivet, the part number is X15 and you get 4 for $1.00
2. See if the center hole on the Idler Gear is damaged or drilled off-center.
3. Check your pick-up shoe spring tension......Here's a quote from you: "It seems to run slow in forward but when I turn the car the other direction on the track it screams." Does it scream while you are holding it, or does it actually "run" fast on the track??? If you are holding it, you may be a much better electrical contact between the pick up shoes and the rails, thus getting more current to the motor so it is running much faster.
4. Check the chassis for warpage.
How to check the OHMS on a pancake(T-Jet, AFX, M/T, JLTO, X/Traction)
1. Touch your meter leads to any two of the three commutator plates on the bottom of the armature. This will give you a reading of the resistance on the wire on the corresponding pole of the armature(Plus some of the resistance of the other two poles, since the motor is a complete circuit of three connected poles) Also, touch the center shaft of the armature with one of your leads and touch the other one to the commutator plates one at a time. If you pick up any resistance then you have a "short"(the insulation on the wire is damaged and is making contact with the pole of the armature) in one of the poles and the armature is junk.
If you need any parts for your M/T(or any other cars) or if you are looking for a VERY COOL place to race check out Jeffrey Stillwell's place in Marietta, GA.
His webpage is
www.stillwellracing.com He has redigned both of his tracks so the pictures on the website are "out of date", but still pretty impressive. I have raced there(and work as a volunteer race official during the WinterNats which are there every Feb.)
You can also call Jeffrey in the evening at 770-971-0571 to get in touch with him. Just tell him some old bald guy who goes by the name of "Rawafx" (Raw-A-F-X) sent you.
Good luck with your M/T!!!
Bob Weichbrodt
"Rawafx"
A and H Hobbies
Winston-Salem, NC
