1 - 12 of 12 Posts
BANNED
buy in bulk
some rules require you to buy production axles. i do that, but i have lots of runners i like to tune, so i buy axle material in bulk. cuts easy with a dremel and fiber cutting disk, and what slot head doesnt have a dremel or 3? just remember after cutting that you bevel the ends of the axle so the hubs slide on easy and true. i hold the axle and twist it in my fingers while pushing lightly into the cutting disk. wear safety glasses!
for my magnet cars (tomy turbo, tyco, super g+, bsrt G3) i prefer 304 s/s wire in 0.059 dia. 304 s/s is only slightly attrached to magnets, and the 304 wire below has a really bright polish that makes a great axle.
http://www.amazonsupply.com/stainless-straightened-precision-diamond-tolerance/dp/B003R50276/ref=sr_1_1?sr=1-1&qid=1349635521&filterBy.item_diameter_derived=0.059+inches&filterBy.material_browse=16418721
Ti wire also works well. i have tried both the 304 and Ti and i like the 304 better. The Ti wears faster and is not polished. Ti is even less magnetic, so no pull toward the rear traction magnets. the 304 has just a bit more drag due to the magnets, but the bright polish and longer wear really offset that.
http://www.amazonsupply.com/dp/B001387M22/ref=sp_dp_g2c_asin
same vendor has hollow tube s/s in 0.058.
http://www.amazonsupply.com/dp/B000FN0VGU/ref=sp_dp_g2c_asin
Thanks MKing for the link to 17G hypodermic 304 SS hollow tube.
Here's an eye-opener for you.
I orginally made all my independent Fan Van axles out of Drill blank stock.
Complete with tires the drill gauge axles all weigh 2.3 grams.
The hollow tube axles are identically set-up to the solid core axles.
Ie:same length / number of spacers /hubs /tires etc.,and they come in at 2.0 grams right on the pin.
Roughly almost 14% lighter .
These are axles with no gears,if the weight seems a bit wacky:thumbsup:
Even up to a Modified mag car i'd run them,i don't know if i'd run them above that in the radical classes,but it's an axle option you guys should look into.
Any Canucks out there using Amazon ,be prepared to take it where the sun don't shine ,when it comes to shipping into Canada from them.
My final bill on $56.16 worth of tubing was $102.90 by the time it was at my door,ouch.
Rick
Axle weight differances for youse guys .
All axles are as close to identical as i could get.
1.5 inches long
0.058" 17G hollow tube : 0.2 grams
0.0595" drill blank : 0.5 grams
0.062" drill blank :0.6 grams.
Rick
1 - 12 of 12 Posts
