1 - 1 of 1 Posts
RDRP have released some new items for the popular Team Durango DEX210/DEST210 and DESC210 vehicles. First up for the DEX210 are the shock towers machined from high-quality 7075-T6 aluminium. Stronger, than any other plastic or carbon fibre part it´s simply impossible to break it. The additional holes for your shock-position will also help you for fine-tuning your car. The next item is the 7075-T6 aluminium steering plate, which fits the Team Durango DEX/DEST and DESC210 series. An additional hole at the front improves the Ackermann geometry a lot, especially in tight corners you will feel the difference. Finally the Brass RF suspension mount also fits all vehicles of the DEX/DEST and DESC210 series. With a weight of 30 grams it helps to plant the rear-end of your car on the track, especially in the MM configuration. First to be released is the 3/3 block with the 0/3 and 1.5/3 blocks to follow.
Source: RDPR [revolution-rc.com]
More...
1 - 1 of 1 Posts
