1 - 14 of 14 Posts
Hey guys,
I am planning on painting my body a solid candy blue. I have heard that I should back the blue with a silver to make the color come out more. Is it really true? And if so does it make a big difference? :confused:
-Dustin
Your coats should be very light, it seems odd, but it is true. I paint my bodies where they are very translucent after 3 coats of color, then back them with silver/white/or black, depending on need. I only use Faskoat on Nitro bodies...as it is very resilient to fuel and scratches, but it is also the heaviest coating. I don't use it on Onroad bodies unless I am 5-10grams under weight. Spraying paint in light coats WITH good coverage requires a decent airbrush. If you are going to use Pactra paint, make sure you put the cans in warm water prior to use...not HOT water. :) It reduces the viscosity of the paint and sprays much finer.
Mitch
Courtesy of Mitch's Vinyl
Discussion Starter · #9 ·
Mitch
How long do you leave it in the warm water? :confused:
-Dustin
1 - 14 of 14 Posts
