1 - 14 of 14 Posts
i bought for a good price a 100 pack for deans bars, and realized a bit late they are the 2.0 probars...
before i open the pack, will these work on the ib4200's?
i noticed the probar 2.0's are a bit 'raised' on one side slightly.. (good for old school 3300's...
the store doesnt offer returns, only store credit =(
Hi Mits,
If you set a Trinity cell-separater (or two, eye-ball it) washer under the positive end (in the down position) to raise the bottoms a tad on the top where you're soldering, they'll work fine. That puts the bar-end with the greatest bend on the "lowered" positive button when soldering.
If you use a full battery jig, strips of cardboard saltine cracker box placed through the slots where the positive buttons will set raises them up enough, too. Just move them to the alternate slots when you flip over the battery to solder up the other side.
If you glue up your cells before soldering, just place the spacers under the alternating cells against whatever "wall" to which you settle them. I place my cells in a Losi battery box and jiggle them against the right-angled area to align them. Then glue them up while they're in that position.
It makes for a tight fitting pack, though, with the off-set bars.
:) Gene
Put the fat side in a vice and compress them till u get them where u want them.
Yes - I have made a die that I use in a vise to re-form the ends of very battery bar I use nowadays to reduce the height of the bend and still keep the ends flat with each other.
Under the plating most of these bars are copper and fairly soft, a med vice is all it takes to reshape these bars(not to say your die isn't a better idea.
The die is used in a vice so that there is still some offset to the ends and both ends are on the same plane so they are flat against the battery terminals. I'll get some pics up as soon as I can find them on my messy workbench, but they are real simple. Basically 4 pices of roofing copper I got from a hardware store soldered together to make the two halves of the die.
Finally some pics of the die I use to flatten battery bars...
This shows the die in use in a vise:
This serves two puroses: 1) it reduces the offset of the end of the battery bar, and 2) it assures that the battery bar end is perfectly parallel to the middle. When both ends are parallel to the middle, the bar will sit perfectly flat on the battery terminals.
Here is a pic with the vise jaws open:
and last but not least, a pic of the die halves sitting on a piece of paper:
You can see that each half is made up of two pieces of copper sheet soldered together and arranged so there is an offset (or jog) when they are placed opposite each other in the vise.
1 - 14 of 14 Posts
