I'm finally getting to work on my door track and I've got a couple of questions:
I'm using the 1" pink insulation board on top of the door to insulate noise. I can srew/nail the track down on the lover level, but how do you guys secure the track when the foam goes up for the over/under? there's 3" of foam, so I can't screw it to the table. Do I just use an adhesive like what I used between layers of foam?
Do you find that nailing or screwing down the track works best? I'll be going through and drilling out the mounting holes so I can flush mount whatever I'm going to use to secure the track.
Do you go so far as to try and fill the connecting gaps between TOMY track with something (what?) so they're less visible? I'm wanting to paint the track surface grey (rattlecan primer taken from another tip on this board) but when the track is lighter it realy shows the joints.
Thanks for the help. I'll start taking some pics and post my progress.
