I have a Tyco layout that I just adapted for 45 ohm Parma Turbo controllers.
What I did was essentially cut the plug off the Tyco controller, split the wires, and soldered them to lugs going through the retaining wall. I want to wire the brake circuit, and from what I have read, it is just wired to the negative track circuit. The diagrams I have seen show that the Positive voltage goes through the controller and the ground is straight from the power supply. My problem is that the Tyco track power is supplied in reverse. The ground goes through the controller and the positive connects directly to the track. Is it okay to run the brake circuit to the positive power going to the track rail which is not connected to the controller? Im sorry in advance if this is confusing to read.
