Hey guys... I'm new here and have a question regarding where can i post pics and details of the 1/4 Scale ProStreet Beretta I'm building... I'm thinking this section is just for QSAC cars... Is this so???
Thanks
Stoney
Thanks
Stoney
Stoney. If its 1/4 scale go ahead and post it here. We all love new things. I have seen some deteils of the car on Mikes site and it looks awesome. POST it.
Thanks!
O.K. a little info on the Beretta build.. The Beretta dimensions with the body on will be,
12 1/2'' H x 18 1/2'' W x 61'' L, 68'' in length from front bumper to wheelie bars.. The chassis is constructed from 3/8'' steel automotive brake line, Fully MIG welded The custom sheet metal type rear end is constructed from 1/8'' steel plate cut to size and MIG welded together.. the gears are BOSCH ring N pinion grinder gears.
The struts and rear shocks are constructed from automotive lift supports.
The springs are from a manual garage door..The Beretta body will be constructed from sheet metal.. That will be attached via body structure.. It will have a one piece front end,, that's removable... Removable & Operational doors... Removable deck lid.. Operational sun roof.. Complete body ground effects package.. Pro/Mod type rear spoiler...Ken Hurst 1/3 scale Blown V8 engine..
If i we're to guess i would say the Beretta will weigh around 70+ lbs once completed.. And it should be completed within two years or so... I also have a web site on the Beretta build and a few other projects if you would like to follow my build progress.
Here are a few shots of it as it currently looks... It don't look like much yet but it will be one sweet looking ride once completed..
Guys i guess i couldn't post the links and pictures in that last post.. keep getting the message as follows..
( To be able to post links or images your post count must be 2 or greater. You currently have 1 posts.
Please remove links from your message, then you will be able to submit your post.)
Here are them links and pics,
Gears..
Ring.. http://www.ereplacementparts.com/crown-gear-p-51884.html
Pinion.. http://www.ereplacementparts.com/bevel-gear-p-51885.html
Struts/Shocks... http://www.autopartsbylou.com/
1/3 Scale Blown V8 engine... http://www.nvbackflow.com/engines/
My Site... http://www.quarterscaleprostreetberetta.com/
