I have a Wheel Horse 82-08BP01 riding mower.
Lately the engine has started surging. Gets so bad that it keeps wanting to die out.
It will run ok (still surges, but will keep running) until I engage the mower deck. Then it just wants to die.
When it started, I looked over the carb and noticed that the spring on the throtle cable had broken. I replaced that, but it didn't solve the problem.
Next, I pulled the bowl off and cleaned everything out.
Helped for a little bit, then the problem started again. In other words, I finished mowing my yard no problem, but when I went to mow the next time, the problem had re-surfaced.
When I first start it, it runs fine, but as I am going around the yard, the problem starts again. Seems to happen when I get into one of the hilly areas of my yard. (not steep, but noticably not level). As soon as the front of the mower dips down a bit, the problem surfaces, and won't go away unless I let it sit for about an hour or so.
Any idea what the problem might be?
