ok so what are the benefits /reasons pod mounted or body mounted wing -- can someone explain
Yep,I was told a couple of season ago that a pod mounted wing pushes down on the chassis which would help plant the rear better and a body mounted wing just pushes on the body not as much force on the chassis. I don't know if this is true but its what I was told.
Only way to go!!! :thumbsup:It also depends on the track surface. Most of the cap tire tracks up north here, we run the wing on the pod.
