Pro-Line have released the Flo-Tek designed specifically for your Traxxas Slayer Pro. The Flo-Tek was the first SC body specifically designed to minimize the short-course body parachute effect. Featuring futuristic styling coupled with large vent holes that allow air to flow through eliminating aerodynamic drag. The locations and size of the vents were designed to maximize air flow through the body while keeping the aggressive and high-tech look. The all new and improved Square Fuzzie is now available for your SC Truck and features countless square micro-pins laid out in a traction inducing grid pattern that will stick to the track like Velcro. The long center bars provide tons of forward bite and improved wear over the Original and are ideal for any indoor/outdoor hard-packed dirt track where bar-type tires are not getting the job done.
Finally for your Losi 5ive-T or HPI 5SC (rear) is a pair of 1:5 scale Blockade XTR No Foam Tires. The Blockade features large, perfectly spaced lugs that rip into the dirt for incredible traction and has plenty of meat to last through super long race sessions. For super loose conditions, the Blockade tire can be tuned for more aggressive traction by trimming out alternating knobs. The inside of the Blockade contains unbelievably detailed webbing that strengthens the tire carcass and prevents excessive tire expansion.
Source: Pro-Line [prolineracing.com]
More...
