1 - 20 of 30 Posts
I believe I have a pink or flesh colored Aurora tjet chassis. I got this car from a neighbor back in the seventies back on Long Island. I think it came on a white camaro with the number 2 or a split window metallic copper corvette. I'm not sure ....my memory isn't good! It is a very fast chassis. Has anyone seen one of these? I asked at a slot car show about 20 years ago and someone said Aurora may have played around with some different dyes. I forgot to bring it to the show to show people. I'm just curious about after all these years. pink aurora.jpg
WOW ! That is Unique ?
Funny thing tho, the top plate retainer clip is from an AFX Magna traction, and the idler gear appears to be black plastic/delrin? In a way, that dates the chassis around 1973'ish ?
Correction on my statement. After blowing up the pic a bit, I see the tooth faces on the idler gear are shiney brass, so that gear is not plastic, my bad. But the Top plate Clip is from a AFX MT, but that could have been easily swapped at any time in the chassis' life.
LED Burner Outer
One possibility is it's a resin chassis. I recall someone telling me Dragjet managed to cast some chassis in resin and rivet the electrical stuff on them.
Yes, I've played around with it through the years and that top clip probably isn't original. I may have originally got it with tuff one rims on it too. I never heard of dragjet. Are they around from the seventies? It maybe hard to tell but it has the us patent numbers on the gear plate like original Aurora. It also has a green wire and red tipped armature. The armature maynot be original either. I may have swapped it out.
how does feel/twist compared to a standard t-jet chassis?
it looks like it may be a different plastic??
not sure the org t-jet plastic would be opaque?? kind of looks that way from the pic
Model Murdering
Dont quote me directly, but I have a memory that Chris did some (typically) high quality resin Magnatraction chassis in some cool colors.
That is none of the above...:tongue:
I dont remember any T-jet castings...but many moons have passed. :freak:
LED Burner Outer
If it is a resin cast, the mold would have picked up the patent numbers from the master. It's cool none the less! Maybe Aurora was shooting for a Mary Kay Jr. car? :tongue: :jest::lol:
Discussion Starter #9 (Edited)
more pics
Thanks for your thoughts. Here are some more pics. The patent is 3243917. The same as on my other t-jets. I guess that would make it aurora? It isn't opaque. I think the flash is washing out the color. I really would describe it as more of a flesh color. If you want to see more pics, just tell me what you want to see. car 1.jpg
LED Burner Outer
Anything is possible. If it was just the top plate or base that was an odd color, I would assume the part was one of the color transition pieces when they switched molds in the factory. Seeing both together makes it harder to explain. Besides HO and O scale drivers, Aurora did make models of planes, monsters, and cars so they were no stranger to flesh color plastic.
A couple possibilities exist. It could have been a test subject after a mold change that slipped out of the factory. They could have stopped production of whatever they were molding in flesh color to test the molds after a revision. Or it may have been specially cast for a prototype that never really made it. It is a cool piece though!! (Don't mind my earlier ribbing!!)
BANNED
a lot of stuff that thrown in the dumpsters during regular manufacturing was fished out. most people just hung onto that stuff. could have been something as simple as a batch of plastic didn't have the right color mix and it was caught quickly, thrown away and rescued.
any number of reasons.
I think that someone here, hilltop?, was making resin chassis for shelf queens. I have a clearish resin chassis from phillycheese something on ebay, Phillip.
but if the chassis in question here is as old as said, it is unlikely a resin repro.
LED Burner Outer
I totally missed that "70's part of the first post, so you're right about it not likely being resin. Someone dumpster diving on multiple occasions, or an Aurora employee taking transition pieces to make oddball chassis from are probably the most likely source.
LED Burner Outer
My resin assumption was a mistake on my part. I got so wrapped up in the pictures I completely missed the "70's timeline. After looking at the bottom view blown up to humungus size on my computer screen, it being solid rivet and all, I am left to assume it's genuine. I've tossed a couple possibilities out there, but another possibility is...
A plant foreman, (the guy who decides production) has a daughter who wants pink T jets. So he goes out of his way to schedule chassis production following something pinkish, be it model parts or whatever. He snags the transition pieces from the line. Then he assembles these pink chassis on his time and may have even paired them up with pink bodies. Hey, anything's possible!!!!
After looking at the latest pix, blown up super-size. I'm now thinking this chassis might have been molded from Pure Nylon, instead of the Nylatron which has the slippery molydenum mixed into the nylon..... maybe the answer is as simple as the mixture was off ?
Cut it??? LOL
Yeah cut it up into pieces and share with us.. LOL
Looks cool, keep the sharp tools in the drawer...
-Marc and Marcus
Model Murdering
Ahhhhh....good theory....a change over piece.
I never did any t-jets at all in resin.That is one very cool piece that some employee may have just said"man what if i shot this through the mold"?
Just my ramblings.
Give ya a buck for it??:thumbsup:
Chris
1 - 20 of 30 Posts
