Hello all,
I have an Opentopbus White 706 bus that I need to repaint. The original clear coat is bubbled so off it goes. Any suggestions as to the best methods and products needed? Many thanks in advance.
Don
Administrator
There are several ways to go about it. Aircraft Stripper is probably the fastest.
If you have health concerns or issues. A Super Clean (soak) will take a day or two.
Administrator
That is the right stuff. You could use enough to soak one side at a time - that will take a bit longer to accomplish of course. I reused my soaker tub over and over before I changed it out.
I have also heard of people using oven cleaner. IIRC correctly not quite as fast as the Air Craft Stripper but will accomplish the job almost as well. 🤙
