I finally got the engine running the other day. It ran fine but one of the small valve covers was leaking. I fixed that then tried it a few days later. It seems to only run with the choke on. If I shut it off at all it stops immediatley.
The engine is a 18HP B&S twin cylinder.
he engine is almost new but had some nternal problems. What shoud I check first?
I took off the top of the carb, there was plenty of fuel and it looked clean (needle valve not sticking).
