I have a canon printer/scanner. i have never tried to make decals, what are the steps and what do the different decal papers do such as white & clear ? I do not know how to resize a picture of a scanned sheet any tips are appreciated. my printer is an ink printer do you need any special methods ?
Testors sells some ink-jet compatible decal paper in clear and white.
There are others out there and I don't remember the brand I got.
You have to keep in mind that your printer depends on the paper to give you the color white. There are super duper printers out there that will print white but, if you use white decal paper when you need it, you can skip this for the most part. Not a perfect situation but very, very good.
For the most part, you'll use clear decal film and print the various colors on it for transferring it.
You'll need some sort of photo manipulation program to change the scale of the decals. If you want to create your own from scratch or make more radical changes, you may need something like Corel PSP (inexpensive but there are even free programs out there as well).
You'll have to carefully measure the test results (on paper) to make sure you have the size right. You may even have to redo the decals if you're not quite there after having applied some only to discover they're the wrong size.
Once you print up your decals, you'll need to spray them with glosscote or some such in order to securely seal in the ink to protect it from the water.
I've made my own decals and even printed up fake deguerreotypes using clear decal film. It's fairly easy to do but be prepared to waste at least a little decal film--it will happen :wave:
