Hello guy,s I received my Grandfathers Roper tractor after his passing and need some help .It came to me minus points and condensor and governor arm unhooked and need to know how the said ignition parts are wired to each other,also putting the governor arm back on the shaft does the shaft get turned full clockwise or counterclockwise.I do not want to convert to electronic coil because Grampa had a new coil for the tractor .If anyone has a wiring diagram I would sure apprecate it. Thanks Kevin
