61 - 69 of 69 Posts
Discussion Starter #62
That looks like the AMT kit with the back modified.
The pylons mount in at the body, the rear landing gear is round, the overall shape, and the top curls all look like the AMT kit.
Nice find! Thanks for posting the photo!
Discussion Starter #63
With the new AMT kit imminent, I broke out another of my old Galileo kits out with the Larson Designs update kit.
Here is the 3 piece back dry fitted:
Much surgery is required!
The large cutting is done, now comes the fitting. This will be interesting getting the back
to fit.
Discussion Starter #64
I've started some painting. It will have to be touched up I'm sure.
I'm going with Insignia white and Tamiya grey primer again. I'll do a light green interior again, but the top and bottom hull parts will be glued together on this build.
I used some clear plastic packaging left over from my eagle metal parts packaging to make an engine insert.
Discussion Starter #65
I've mounted the resin aft end to the lower hull. I've also installed the stock interior. Not much will be seen through the
front windows, so I'm not adding anything to it.
The same light green and black paint on the interior.
And the left side attached.
Discussion Starter #67
Well, from "The Galileo 7", "Metamorphosis", and "The Doomsday Machine" It could be considered
"Unsafe at any Warp"
Pretty neat!
I'm liking it 😁
-Jim G.G.
61 - 69 of 69 Posts
