1 - 1 of 1 Posts
I have 2 pressure washers with the same problems. Both Honda engines are seeping oil out of the bottom. The model numbers are GX 270 and GX 390 both are horizontal shaft. It appears to be coming from the gasket on the shaft side of the engine. How common is this on the Honda's? To inspect and confirm my suspicions I have to take the pumps off of the engines. Just checking to see if anyone has similiar problems with Honda. Thanks.
I have checked over the engine case and there is no oil dripping from the oil fill, oil drain etc.
1 - 1 of 1 Posts
