Really it depends on how anal retentive you are, and how much patience you have. Simple green and a pressure washer usually won't hurt coil packs unless you have one going already. That's not to say that it never will, but they're not like the opti distributor in the LT1 cars where you absolutely cannot get them wet. If you go that route, I recommend spraying it with the pressure washer while it's running. Keep the spray away from any air inlets and you'll be fine. If you develop a miss, you have a coil that was cracked and going to go already.
Now if you really want to get deep into it, a set of brushes from autozone (one brass, one steel, one nylon slightly bigger than toothbrushes) a can or bottle of degreaser, water in an empty windex bottle and do it by hand. Wipe everything down with semi clean rags as you go scrubbing the tough spots with one of the brushes depending on the surface. 000 steel wool works well too, especially on chrome. For the rubber and plastic pieces, pick up a can of dry silicone spray - it's readily available at AutoZone. Spray either the rag or the part (hoses and wiper blades are okay too.) It will clean and condition them but not make them too shiny or sticky.
Hope this helps!:thumbsup:
Here's the engine of the '68 with about 12000 miles on it now...
