1 - 2 of 2 Posts
In the photos of the ship, it appears the top/front end of the warp engine pylon is twisted downward/outward to get the nacelle level from a side view. The Art Asylum toy does exactly this, yet is able to maintain the centerline of the engine with the centerline of the ship from a top view.
Has anyone worked out the best way to contort styrene plastic to achieve this twist? Or is there some other method of correcting this flaw?
Discussion Starter · #2 ·
No leads, eh? Alrighty, then. I'll figure out a solution and post it. I did see some ideas mentioned on the PL board, but they weren't terribly detailed or described very well. I'll see if I can accomplish a medium heat twisting of the pylon by roughly 5 degrees top front outwards. If worse comes to worst, I can try casting the part in resin and working with it that way.
1 - 2 of 2 Posts
