Just an Idea to throw out ,,,, we all pretty much agree that heat is the enemy of batteries and when you take todays high capacity cells and cycle them at either 30 or 35 amps , they get some hot !!
To back up ,, I believe the matchers need to cycle at 35 amps to find the stongest cells and discharge to .90 for an accurrate runtime.
This is my thoughts ,, we all want to know the voltage of the pack at a certain time into the race and the IR rating of that pack to tell us the punch factor.
What I've been doing is this ,,, which happens to be with a GFX unit, Set your charge / repeak settings to your favorite amperage ,, Set your discharge setting to 35 amps ,,, but set your voltage cut-off to " 4.60 " volts and with IR on of course and put your GFX on cycle mode and start .
What you'll get is this ,,, a very accurate measurement of a high amperage discharge without overheating the pack " you have to remember that when these cells were cycled at the matcher they were not glued together and they dissipated heat alot better " , any decent pack will still run for almost 400 sec's and will be above 4.80 at the 300 sec. mark.
I measure my packs 300 sec average voltage by manually taking readings off the graph every 30 sec's to give me an average voltage ,,, 5 , 30 , 60 , ect.
The pack will stay much cooler with this shorter discharge cycle and give you all the information you need for any 4 or 5 min race.
If you really need to check runtime for an enduro or something , then use the .90 method but otherwise I feel your just cooking your cells !!
JUST MY OPINION , FEEL FREE TO COMMENT OTHERWISE :thumbsup:
