The all new Pure Evo SpecRacing motor from Nosram claims to be the new benchmark for stock racing worldwide. Based on years of experience and racing success, Nosram has designed a spec racing brushless motor that is based on the World Championship winning Pure Evolution modified platform that combines extreme power with perfect controllability. Together with the new ‘Easy-Tech’ features, these motors are the perfect combination of top class brushless motors and fair racing for controlled stock racing.
</img>
</img>
More...
Features:
- HDS Technology: High Density Short stack for highest power output.
- New StockSpec Magnet: High strength sintered 12.45mm magnet with maximum dimension allowed by the rules for maximum performance
- PreciSensorTM System: Revolutionary precise sensor positioning for best power, throttle and efficiency. Fully adjustable and replaceable.
- Reproducible Timing: Timing adjustable in clearly defined, reproducible steps with the new molded timing inserts for same result every time.
- Dismountable: Machined 7075-T6 aluminum can, short/lightweight design and maximum airflow.
- Easysolder Design: Heavy cooper, multilayer PCB for lowest resistance.
- Oversized Ball Bearings: Oversized ball bearing for highest performance and durability.
Source: Nosram [nosram.com]- HDS Technology: High Density Short stack for highest power output.
More...
