61 - 71 of 71 Posts
Discussion Starter #61
Guys, I plan to get back into racing at your track for the winter season, can you give recommendations for 12th scale spec car. Don't need anything high end, just a solid car that I can get started with. I'm leaning towards CRC or Team Associated.
An older CRC will work just fine and we have parts at the track :)
Thanks for the quick response, I have a older CRC. The next date you guys are open, I will come out and purchase the parts needed to get started, also will purchase a membership. Thanks
Discussion Starter #63
We will be there this Saturday :)
Hey Guys, I I need recommendations for 12 scale spec, thanks for all your help yesterday Sg1.
Esc recommendations?
Regulator for my 2s Novak edge esc?
Power supply basic will do.
Can I use team associated body post?
Thanks in advance
Discussion Starter #65
Thanks in advance
There are some cheaper 1s ESC avaialable out there, I have a few of those on their way :)
I also have a hobbywing booster coming, you could still use your Edge if you wanted to.
Ebay has great deals on power supplies:
12V RC Power Supply 75A 900 Watts for Powerlab 6 8 Icharger 4010 406 308 | eBay
Associated body posts work great, if you need different length ones we have some CRC at the track.
Okay, that works great, I will just purchase everything from you. Check eBay for power supply. Thanks for the help.
I picked up a lightly used CRC XTI-WC to run 1/12 Spec. I have ZERO experience with pan cars. What are some good starting points for the chassis setup?
-Dampening tube lube?
-Rear shock oil?
-Front camber?
-Front caster?
-Front toe?
Any other tips would be greatly appreciated!
Discussion Starter #68
-Rear shock oil?
-Front camber?
-Front caster?
-Front toe?
With 17.5 changing to spec tires here's what I've been doing to get mt car to work with them:
5k to 7k dampening in tubes
40wt center shock oil, red center spring
1/2* camber
5* castor blocks
1/2* total toe out
glue front side walls
Only apply traction for 3 or 4 minutes then wipe off and let sit 3 or 4 minutes
Full traction rears, inside fronts up to purple stripe.
1/2* camber
5* castor blocks
1/2* total toe out
Thanks!
Stupid question, but I just spent a half hour Googling it and couldn't find a definitive answer....
Running a Kimbrough 78t 64p spur for the 1/12 Spec Class on a XTI-WC, am I going to need 3/32 or 1/8 diff balls?
Thanks!
Discussion Starter #71
All right... The current points series for oval and onroad are done!
We'll get the final points tabulated and awards ordered.
I'll have a new thread started with the next point series :)
The website is still down, so watch here and on FB for updates and or changes till the website gets up and going again.
61 - 71 of 71 Posts
