Oh no!!! Not the cold heat gun!!! I bought one of those from the shack.. The tip is very fragile and busted two with in a month (at 10.00 a pop!). I know what you're talking about Tom, just can't recall where I seen it. I never tried it so I can't say it'll do the trick for you. For soldering I can give you a couple tips, and I'm sure someone else will jump in and give you more.
For one, make sure the surface you are soldering on is roughed up a bit. Like paint, solder needs something to bite to. Scratch it up with a small screw driver. This is especially helpful when soldering to flat surfaces like Tjet shoe plates.
I use a paste rosin soldering flux (the shack) before hitting the solder. A tiny spot is all you'll need to get a good bite.
Make sure your iron has a decent tip, and is hot before you start.
Pre-solder the spot where you're working before attaching what you're soldering to it. Also, pre-solder the wire you are attaching. Let it all cool down before reheating for attachment. You want the metal hot, not the plastic around it so use caution, don't overheat the metal, and it should all go together easy.
Watch the fumes when using solder, and even more so when using the flux. It doesn't smell nasty for no reason!!
Good luck with your project!! :thumbsup:
