have a kohler 10 hp that will not start. has good spark, pour gas into spark plug hole and will not try to start. compression is 50 lbs. is that too low for it to start? could use some advice thanks chexeye :confused:
WOAH! 50lbs? waytoo low. tighten the head bolts but do not over do them and strip the threads, check for a valve thats stuck up a little by the piston, and make sure your gaskets are not burnt out or just no gasket at all. then check the piston rings, maybe there too small or big/loose and let air pass though them, last of all check the spark plug, tighten the plug but do not overtorque it or stip the mountings. ony
Ps what did you use to check compression? and if those dont work.. or u get good compression, but it still wont start check carb and make sure your not putting too much gas into cylinder
