i have a weedeater featherlite fx 26s xtreame 16in. cut 25cc engine. spark is good with plug outside of engine. i put starting fluid in plug hole & replace new plug & enging does nothing. it has a built in flywheel key. has good compression. i have tried all i know. i have worked on endines 50 yrs. this has me stumped. i welcome any help. plowmule
Hi Hankster, Thanks For The Reply. The Compression Is 50 Lbs. This Weedeater Had Broken Off At The Top Of The Shaft. It Sit For Two Years & Had Been Only Used A Few Times. It Looks New. I Cut The Bad End Of Shaft Off & Shorten Drive Shaft By Grinding Off Some At Each End. I Soaked Carb Over 24 Hrs , Took Off Muffler, & Cleaned & Checked Everything. New Plug, Has Good Fire Outside Of Engine. Like I Said It Will Not Make A Pop Even With Starting Fluid Put In Plug Hole. I Appreciate Your Help. You Are On My Buddy List.-----plowmule
50 psi sounds like ring may be stuckin grove or piston / pot damage
Discussion Starter #6
I Took Head Off & Cleaned Everything, Ring Not Stuck, Put Thin Coat Of Grease On Gaskets, Put Back Together. Compression Went To 80 Lbs & Engine Started. Thanks Hankster & Billsmowers-------plowmule
